- Admin
- #1
Meucci Engine ECU Decoding
What is Mecucci Engine ECU Decoding?
Mecucci Engine ECU Decoding is a software used to repair vehicle immobilizer system problem caused by ECU’s or IMMO boxes or in situation where all keys have been lost.It can also be used for track cars where a donor engine has been used or an ECU swap out. This is an advance tool with a comprehensive coverage for all locksmiths and ECU repair stations worldwide.
Mecucci Engine ECU Decoding Features:
Turn the IMMO off
Extract the PIN
No Need Hardware
Mecucci Engine ECU Decoding Support Operation Systems:
Work on Window XP/7/8 32 and 64 bit.
Try it on other version OS.
How to Use Mecucci Engine ECU Decoding:
1.Use ECU Read/Write programmer to read out ECU immo dump
2.Select the vehicle brand and ECU type in the families list
3.Click “Decode file” button to decode,then save it on your laptop
4.Write the dump file decoded by Mecucci back to ECU.
ALFA
BOSCH 24C04 EEPROM EDC15C5 -X (P)
BOSCH EDC15C6 EEPROM 95P08 (P)
BOSCH EDC15C6 FLASH 29F400 EURO 3 (T)
BOSCH EDC15C7 EEPROM 95P08 (P)
BOSCH EDC15C7 FLASH 29F400 EURO 3 (T)
BOSCH EDC16C39 EEPROM 95640 (P) + CRASH RESET
BOSCH EDC16C39.X FLASH MPC (T)
BOSCH EDC16C8 EEPROM 95160 (P)
BOSCH EDC16C9 EEPROM 95160 (P)
BOSCH M2.10.3 24C02 EEPROM ( T.P )
BOSCH M2.10.4 24C02 EEPROM ( T.P )
BOSCH ME7.1.1 EEPROM 25/95080 (P)
BOSCH MED7.6.1 EEPROM 25/95080 (P)
BOSCH MED7.6.2 EEPROM 25/95080 (P)
BOSHC EDC1.3.1 MSA11 -4 93C46 EEPROM DX & SX ( T.P )
MAGNETI MARELLI 18F.XX MCU 68HC11F1 (T & P)
MAGNETI MARELLI IAW 4Q- J -W MCU 68HC11E1 ( T.P )
MAGNETI MARELLI IAW 8F.XX MCU 68HC11F1 ( T.P )
APRILIA
MAGNETI MARELLI 5AM.XX EEPROM 95160 (P)
AUDI
BOSCH EDC1.3.1 MSA11 93C46 EEPROM DX (T)
BOSCH EDC15M – 5.X EEPROM 24C04 (T)
BOSCH EDC15P EEPROM 24C04 (T)
BOSCH MICRO -6 EDC15P 1037355944 24C04 EEPROM (T)
BOSCH EDC15V EEPROM 24C04 (T)
BOSCH EDC15VM + EEPROM 24C04 (T)
BOSCH EDC16CP34 EEPROM 95320 (T)
BOSCH EDC16U1 EEPROM 95320 (T)
BOSCH EDC16U31 EEPROM 95320 (T)
BOSCH edc16u34 EEPROM 95320 (T)
BOSCH M2.3.2 EPROM 27C512 T
BOSCH M3.2.1 EEPROM 24C02 (T)
BOSCH M3.8.X EEPROM 24C02 (T)
BOSCH M5.4.1 EEPROM 24C02 (T)
BOSCH M5.9.2 EEPROM 24C02 (T)
BOSCH ME7.1 EEPROM 25 \ 95040 (T)
BOSCH ME7.1.1 EEPROM 95160 (T)
BOSCH ME7.1.1 EEPROM 95P08 (T)
BOSCH ME7.5 EEPROM 25 \ 95040 (T)
BOSCH ME7.5.1 EEPROM 25 \ 95040 (T)
BOSCH ME7.5.10 EEPROM 25 \ 95040 (T)
BOSCH ME7.5.2 EEPROM 25 \ 95040 (T)
BOSCH ME7.5.3 EEPROM 25 \ 95040 (T)
BOSCH ME7.5.5 EEPROM 25 \ 95040 (T)
MSA -X BOSCH EDC15 ECU EEPROM 24C02 ALL (T)
Digifant 3.2 27C256 EPROM (T)
SIEMENS SIMOS 2.X 2 PLUG FLASH 29F200 (T)
SIEMENS SIMOS 3.0 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3.1 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3.2 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3.3 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3.4 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3.4A 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3.5 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 2 PLUG 3FT EEPROM 93C76 (T)
SIEMENS SIMOS 3PE 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3PG 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 3W 2 PLUG EEPROM 93C76 (T)
SIEMENS SIMOS 7.1 2 PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 7.1A PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 7.4 PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 7.6 PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 7.8 PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 7.PP PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 8.1 PLUG EEPROM 93C86 (T)
SIEMENS SIMOS 9.1 PLUG EEPROM 93C86 (T)
SIEMENS SIMOS1.X 1 PLUG EEPROM 93C56 (T)
SIEMENS SIMOS2.X 2 PLUG 27C010 EPROM (T)
BENTLEY
BLAZER
BOSCH 24C02 EEPROM M2.8 (T)
Pagina 2 di 20
BMW
BOSCH EDC15C4 EEPROM 95P08 -X (P)
BOSCH EDC15M 6 – DDE 3.0 EEPROM 24C04 P
Bosch MSA 15.5 EPROM 93C46 (T)
BMS46 SIEMENS FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS MMS50 FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS MMS52 FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS MS41 FLASH 29F200 (T)
SIEMENS MS42 FLASH 29F400 ROLLING CODE RESET
CHEVROLET
DELPHI USA 29F800 (P) ROLLING CODE RESET
GM MULTEC MCU 68HC11F1 PLUG RED & WRITE ( T)
KEMSCO FLASH 29F400 (P) ROLLING CODE RESET
CHRYSLER
BOSCH EDC 24C04 EEPROM 15.5-5.3 MSA P
BOSCH EDC 24C04 EEPROM MSA 15.5-5.3 T
BOSCH EDC 24C02 EEPROM 15.5-5.5 MSA P
BOSCH EDC 24C02 EEPROM MSA 15.5-5.5 T
CITROEN
BOSCH EDC15C2 EEPROM 95P08 -6 (T)
BOSCH MA3.0 EEPROM 93CS46 ( T.P )
BOSCH MA3.1 EEPROM 93CS46 ( T.P )
BOSCH MP3.1 EEPROM 93CS46 ( T.P )
BOSCH MP3.2 EEPROM 93CS46 ( T.P )
BOSCH MP5.1 EEPROM 93CS46 ( T.P )
BOSCH MP5.1.1 EEPROM 93CS46 ( T.P )
BOSCH MP5.2 EEPROM 93CS46 ( T.P )
BOSCH MP7.0 24C02 EEPROM (P)
BOSCH MP7.2 24C02 EEPROM ( T.P )
BOSCH MP7.3 EEPORM 24C02 ( T.P )
BOSHC EDC 1.3.8 MSA11 -3 93C46 EEPROM DX & SX (TP )
LUCAS EPIC MCU 86HC11E9 ( T.P )
MAGNETI MARELLI 48P3X EEPROM 25/95080 ( T.P )
MAGNETI MARELLI 4MP.XX FLASH 29F200 (TP ) ROLLING CODE RESET
Pagina 3 di 20
MAGNETI MARELLI 5NP EEPROM 95160 (P)
MAGNETI MARELLI 6LP ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP.39 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP.PB ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.09 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.17 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.18 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.19 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.20 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.28 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.40 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.43 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.49 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.51 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.55 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP1.58 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP2.03MCU ST10F280 (P) AUTOCODING
MAGNETI MARELLI 6LP2.05 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LP3.15 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPA.01 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPA.02 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPA.03 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPA.04 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPA.05 ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPB ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPC ST10F280 MCU (P) AUTOCODING
MAGNETI MARELLI 6LPX ST10F280 MCU (P)
MAGNETI MARELLI G6 MCU 68HCA1 ( T.P )
MAGNETI MARELLI IAW 48P2.20 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.30 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.31 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.36 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.37 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.38 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.39 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.3C 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.3G 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.3T 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.3V 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.3W 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.40 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.41 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.60 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.70 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.72 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.76 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.78 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.79 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.7H 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 48P2.80 29F400 (P) AUTOCODING
MAGNETI MARELLI IAW 4MP.11 29F200 (P) AUTOCODING
MAGNETI MARELLI IAW 4MP2.01 29F200 (P) AUTOCODING
MAGNETI MARELLI IAW 4MP2.05 29F200 (P) AUTOCODING
MAGNETI MARELLI IAW 4MP2.15 29F200 (P) AUTOCODING
MAGNETI MARELLI IAW 4MP2.20 29F200 (P) AUTOCODING
MAGNETI MARELLI IAW 8P.XX MCU 68HC11A1 ( T.P )
SAGEM 2000 EEPROM 25/95080 P
SID 801 95C56 EEPROM (P)
SID 801A 95C56 EEPROM (P)
SIEMENS SID 801 FLASH 29F400 ROLLING CODE RESET
SIEMENS SID 801A FLASH 29F400 ROLLING CODE RESET
SIEMENS SID 802 FLASH 29F400 (P) ROLLING CODE RESET
SIEMENS SID 804 FLASH 29F400 ROLLING CODE RESET
SIEMENS SID 806 FLASH 29F400 ROLLING CODE RESET
SIEMENS SID801A EEPROM 93C56 (T)
VISTEON ST10F275 MCU DCU -102 (P) ROLLING CODE RESET
DACIA
DELPHI DCM1.2 EEPROM 25 \ 95160 (P) ( YNIECTOR NEED CODE )
DELPHI DCM1.2 EEPROM 25 \ 95160 (T) ( YNIECTOR NEED CODE )
DELPHI DDCR EEPROM 25 \ 95080 (P) ( YNIECTOR NEED CODE )
DELPHI DDCR EEPROM 25 \ 95080 (T) ( YNIECTOR NEED CODE )
DELPHI TRW EEPROM 25/95080 (P)
SIEMENS SIRIUS32 FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS SIRIUS34 FLASH 29F200 (P) ROLLING CODE RESET
DAEWOO
FLASH 29F200 KEMSCO D3 (P) ROLLING CODE RESET
DAF TRUCK
BOSCH EDC7CX EEPROM 95640 (P)
BOSCH MS 6.2 24C16 EEPROM ( T.P )
DODGE
DUCATI
FENDT TRACTOR
BOSCH MS 6.4 24C16 EEPROM ( T.P )
FIAT
BOSCH EDC15C8 1.31 EEPROM – 95320 (P)
BOSCH M1.7.3 24C02 EEPROM ( T.P )
BOSCH ME7.9.10 EEPROM 25/95080 (P)
BOSCH ME7.9.6 EEPROM 25/95080 (P)
GM MPI MCU 68HC11F1 PLUG RED & BROWN ( T.P )
GM MPI MCU 68HC11F1 PLUG RED & WRITE ( T.P )
LUCAS DCU3F EEPROM 25/95080 (P)
Magenti MARELLI 49F EEPROM 25/95040 (P)
Magenti MARELLI 4ER EEPROM 25/95080 (P)
Magenti MARELLI 4GF EEPROM 25/95040 (P)
Magenti MARELLI 6F3 EEPROM MJD 95320 (P) + CRASH RESET
Magenti MARELLI MJD 6JF EEPROM 95320 (P)
Pagina 6 di 20
MAGNETI MARELLI 1AG7.XX MCU 68HC11F1 ( T.P )
MAGNETI MARELLI 49F/4GF EEPROM 25/95040 (T)
MAGNETI MARELLI 4AF EEPROM 95160 (P
MAGNETI MARELLI 4AF.XX EEPROM 95160 (T)
MAGNETI MARELLI 4SF ST10F280 MCU (P)
MAGNETI MARELLI 59F.XX MCU / EEPROM ST10F168/269 (P)
MAGNETI MARELLI 59FBTX EEPROM 25/95160 (P)
MAGNETI MARELLI 5AF.XX MCU / EEPROM ST10F168/269 (P)
MAGNETI MARELLI 5NF.XX EEPROM 95160 (P)
MAGNETI MARELLI 5NFXX EEPROM 95160 T
MAGNETI MARELLI 5SF ST10F280 MCU (P)
MAGNETI MARELLI IAW 16F.XX MCU 68HC11F1 ( T.P )
MAGNETI MARELLI MDJ6F3 FLASH MPC (T)
MAGNETI MARELLI MDJ6JF MPC (T)
MARELLI 1AB.XX 27C512 EPROM (T)
MARELLI 1AF.XX 27C512 EPROM (T)
FORD
BOSCH EDC16C3 EEPROM 95160 (P)
BOSCH M3.8.1 EEPROM 24C02 (T)
BOSCH ME7.1 EEPROM 25/95040 T
ECCV FLASH 28F200 (P) ROLLING CODE RESET
MAGNETI MARELLI 4AFR EEPROM 25 \ 95160
SIEMENS SID 804 FLASH 29F400 (P) ROLLING CODE RESET
SIEMENS SID 901 FLASH 29F400 (P) ROLLING CODE RESET
Pagina 7 di 20
SIEMENS SID901 FLASH 29F400 (P) ROLLING CODE RESET
SIM 19 SIEMENS FLASH 29F200 (P) ROLLING CODE RESET
SIM 20 SIEMENS FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS SIM 210 29F400 FLASH (P) ROLLING CODE RESET
SIM 22 SIEMENS FLASH 29F400 (P) ROLLING CODE RESET
SIM 24 SIEMENS FLASH 29F400 (P) ROLLING CODE RESET
SIM 28 SIEMENS FLASH 29F400 (P) ROLLING CODE RESET
SIEMENS SIM 280 FLASH 29F400 (P) ROLLING CODE RESET
SIM 29 SIEMENS FLASH 29F400 (P) ROLLING CODE RESET
VISTEON PCM FLASH 28F200 (P) ROLLING CODE RESET
HONDA
BOSCH EDC15C7 EEPROM 95P08 P
BOSCH EDC16C31 EEPROM 95160 (P)
BOSHC EDC 1.3.1 MSA11 -10 93C46 EEPROM DX & SX (TP )
HITACHI 93C56 EEPROM P9L T.P
HYUNDAI
BOSCH EDC 15C7 -X EEPROM 98P08 (P)
DELPHI EEPROM 25 \ 95080 (P)
KEFICO EEPROM 95160 (P)
SIEMENS S -11 1 -5L DOHC 27C512 EPROM (T)
SIEMENS SIMK42 FLASH 20F200 (P) ROLLING CODE RESET
SIEMENS SIMK43 FLASH 20F400 (P) ROLLING CODE RESET
ZEXEL EEPROM 93C46 (T)
ISUZU
BOSCH EDC15M EEPROM 24C04 (P)
IVECO TRUCK
BOSCH m.s 6.3 24C16 EEPROM ( T.P )
BOSCH m.s 6.2 24C16 EEPROM ( T.P )
DAILY BOSCH EDC16C8 EEPROM 95640 (T)
JEEP
KIA
LADA
BOSCH M1.5.4 EEPROM 24C02 (T)
BOSCH MP7.0 24C02 EEPROM (T)
BOSCH MP7.3 24C02 EEPROM (T)
KEFICO M7.9.7 EEPROM 95080 ( T.P )
KEFICO ME7.9.7 EEPROM 95080 ( T.P )
LANCIA
MAGNETI MARELLI 4AF EEPROM 95160 (P)
LAND ROVER
MEMS MKC EEPROM 93C46 (T)
LEXUS
NIPPON DENSO GASOLINE EEPROM 93C46 (P)
MAN TRUCK
BOSCH MS 6.1 24C16 EEPROM ( T.P )
MAZDA
BOSCH EDC16C3.9 EEPROM 95160 (P)
DENSO MAZDA GASOLINE EEPROM 93C56 (P)
MERCEDES
BOSCH EDC15.5 X – P EEPROM 24C02
BOSCH EDC15C0 -X P 24C04 EEPROM ERROR RESET + START
BOSCH EDC15C6 EEPROM 95P08 AUTOCODING
BOSCH EDC15C6 95P08 P EEPROM ERROR RESET + START
BOSCH EDC16C2 EEPROM 95160 (P)
SIEMENS VDO MSE H10 FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS VDO MSM 1.X FLASH 29F200 (P) ROLLING CODE RESET
MERCEDES TRUCK
TEMIC 93C66 EEPROM (P)
MG
3 NNN MEMS 93C66 EEPROM (T )
SIEMENS EMS2 FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS EMS2000 FLASH 29F200 (P) ROLLING CODE RESET
MINI
SIEMENS EMS 2 FLASH 29F400 (P) ROLLING CODE RESET
SIEMENS EMS 2 FLASH 29F400 (T) ROLLING CODE RESET
MITSUBISHI
BOSCH EDC15C3 EEPROM 95P08 (P)
MOTO GUZZI
MOTO MORINI
MV AGUSTA
NEW HOLLAND
NISSAN
Pagina 11 di 20
BOSCH M1.9.5 93C46 EEPROM T.P
MSA 15.5-6 BOSCH 24C02 EEPROM P
MSA 15.5-6 BOSCH 24C02 EEPROM T
NISSAN TRUCK
OPEL
BOSCH EDC 1.3.1 MSA 11-10 93C46 EEPROM DX & SX (TP )
BOSCH EDC 24C02 EEPROM MSA 15.6 (P)
BOSCH 24C02 EEPROM M1.5.X T
GM MPI MCU 68HC11F1 PLUG PURPLE ( T.P )
GM MULTEC MCU 68HC11F1 PLUG & BLU GREY ( T)
GM MULTEC MCU 68HC11F1 PLUG LIGHT BLUE ( T)
GM MULTEC MCU 68HC11F1 PLUG RED & BROWN ( T)
MAGNETI MARELLI MJD 6JF GM EEPROM 95320 (P)
SIMTEC 56.1 93C56 EEPROM (T)
SIMTEC 56.1 93C56 EEPROM (P)
SIMTEC 56.5 27C010 EPROM (T)
PEUGEOT
PORSCHE
BOSCH ME7.1 EEPROM 25/95040 (P)
PROTON
RENAULT
EDC15.X 1 PLUG BOSCH 24C02 EEPROM (P)
EDC15.X 2 PLUG BOSCH 24C04 EEPROM (P)
LUCAS DCU3R EEPROM 25/95080 (P)
MAGNETI MARELLI 5NR2 C5 PCB EEPROM 95160 (T)
MAGNETI MARELLI 8R.30 MCU 68HC11A1 ( T.P )
SAGEM 3000 EEPROM 95160 (P) AUTOCODING
SAGEM 3000 EEPROM 95160 (T)
SIEMENS EMS3132 FLASH 29F200 (P) ROLLING CODE RESET
SIEMENS EMS3134 FLASH 29F400 (P) ROLLING CODE RESET
SIEMENS FENIX 3 MCU 68HC11E1 ( T.P )
SIEMENS SIM32 EEPROM 95160 (P) AUTOCODING
SIEMENS SIM32 EEPROM 95160 (T)
SIEMENS SIRIUS 35 FLASH 29F400 (P) ROLLING CODE RESET
SIEMENS SIRIUS34 FLASH 29F400 (P) ROLLING CODE RESET
RENAULT TRUCKS
BOSCH m.s 6.3 24C16 EEPROM ( T.P ) Truks
ROVER
ROVER MSB EEPROM 93C46 T
SAAB
Pagina 15 di 20
SCANIA TRUCK
SEAT
MAGNETI MARELLI 16S.XX MCU 68HC11F1 ( T.P )
SKODA
SMART
BOSCH EDG15C -5.1 EEPROM 95P08 (P)
BOSCH 24C02 EEPROM MEG 1.0 (P)
SUZUKI
DENSO 27C256 EPROM (T)
SIEMENS SID 801 5WS4 93C56 EEPROM ( T.P )
SIEMENS SID 801A 93C56 EEPROM ( T.P )
TOYOTA
BOSCH EDC16CXX EEPROM 95160 (P)
NIPPON DENSO D4D EEPROM 93C86 (T)
VAUXHALL
VOLVO
BOSCH EDC16C34 EEPROM 95160 (P)
VOLVO TRUCKS
VW
Pagina 19 di 20
MOURAD SPCMAX
APRILIA
AUDI
BENTLEY
BLAZER
Pagina 2 di 20
BMW
CHEVROLET
CHRYSLER
CITROEN
Pagina 3 di 20
DACIA
DAEWOO
DAF TRUCK
DODGE
DUCATI
FENDT TRACTOR
FIAT
Pagina 6 di 20
FORD
Pagina 7 di 20
HONDA
HYUNDAI
ISUZU
IVECO TRUCK
JEEP
KIA
LADA
LANCIA
LAND ROVER
LEXUS
MAN TRUCK
MAZDA
MERCEDES
MERCEDES TRUCK
MG
MINI
MITSUBISHI
MOTO GUZZI
MOTO MORINI
MV AGUSTA
NEW HOLLAND
NISSAN
Pagina 11 di 20
NISSAN TRUCK
OPEL
PEUGEOT
PORSCHE
PROTON
RENAULT
RENAULT TRUCKS
ROVER
SAAB
Pagina 15 di 20
SCANIA TRUCK
SEAT
SKODA
SMART
SUZUKI
TOYOTA
VAUXHALL
VOLVO
VOLVO TRUCKS
VW
Pagina 19 di 20
MOURAD SPCMAX
